DIY Breather Bypass questions
Hey all,
I'm pretty sure I saw a thread a while ago about doing what I'm thinking about, but couldn't find it again after digging through a bunch of breather bypass threads - so if anyone knows where this has already been answered, please point me in the right direction. Anyway:
Current setup: 2011 FLHTK with Harley high flow backplate/paper filter setup, with the breather channels integral to the backplate. As is, I've had the air filter off a couple times recently, and I have gotten maybe a 1/4 tsp of oil sitting on the rubber gasket of the filter where it meets the backplate. No oil spewing out of the filter while riding that I've seen yet.
What I'd like to do: Replace the existing breather bolts that feed the channels in the backplate with stock OEM breather bolts with the 'external' nipples, which I have. I also have a stock breather tube from a rushmore air cleaner that I plan to attach to the nipples, (just needs slight lengthening to reach - a longer T should do it I think) then just route the rushmore hose over the top and behind the backplate. From there I can run a single hose off the bottom of the T, and to the ground.
Now, my questions:
1) Are the stock breather bolts the same length as the bolts for the high flow backplate kit?
2) Do I need to 'plug' the breather channels in the back plate? I'm thinking no, as they will be blind to the heads with the OEM breather bolt installed, correct?
3) If I do this, should I pull the whole back plate assembly and replace the throttle body gasket and O-rings (o-rings aren't really necessary any more, other than to maintain spacing for the back plate, since the blow by isnt' going into the channels in the backplate?), or can I get away with a straight swap of just the breather bolts, leaving everything else installed as is?
3a) What torque value should I use for the breather bolts? OEM bolts go in at 22-24 ft-lbs per the service manual (with the OEM air cleaner setup), and the instructions for the high flow setup call for 120-144 in-lbs (roughly half the OEM value). I'm guessing this is due to the O-rings in the high flow assembly, and I'm inclined to think the 120-144 in-lbs is probably a better choice here?
Thanks folks!
Dan
Now, my questions:
Thanks folks!
Dan
[QUOTE=GregGillette;15466656]Made my own breather bolts as stock and aftermarket were not long enough for my AN Big Sucker intake. Integrated bypass left intact, used recommended torque. If not mine you remember, hopefully helps someone else. Less than $20 invested in threaded rod, hose, clamps and T fitting.
Great job Greg. I and MANY others are A/N BS users, so can you please back this up with a parts list of some sort. I have no idea the thread size or count and would love to pick up the hardware to do this once I am home for the long weekend. Again, very nicely done.
Kris
Kris
Dan
This would be my next step if I can't confidently work this out with help from the community. But I basically have all the parts of the $30 kit (that uses the stock breather bolts) in hand already, for zero cost. My goal here is to see if I can use what I have with reasonable confidence. If that answer is no, then I'll start ordering stuff. Greg, I did see your setup in my hunt - nicely done, by the way - but it isn't the specific post (or it might have been a whole thread??) I was trying to find. Someone either used, or suggested using the stock OEM breather bolts with a non-stock (don't remember if it was Harley, AN, or some other) back plate. I'm fairly certain using the rushmore breather tube was in this post too - looking at it, it certainly makes sense to do so to me. Dan
https://www.hdforums.com/forum/touri...ngine-oil.html
dandrumheller (08-31-2016)
[QUOTE=BlackPearl#1;15467785]
I used 3/8"-16 all thread rod. Final length was 2 3/4". I chucked up a 3.5" piece in my hand drill and secured my selected drill bit in my vice. I made a starter dimple in the rod by hand then slowly drilled the hole thru the rod using oil and frequently removed from bit to clear shavings. I found a video on YouTube for process. Cut off end that was chucked in drill and ran a nut up and down the rod to chase the ends or use a die if have. For the tubing, I used 1/4 id fuel line and T connector and hose clamps. Mines hidden with the stock football cover and run the drain to frame rail, secured with black zip ties. I cut a 45* angle at the end to help direct misting down.
Kris
Kris
BlackPearl#1 (08-31-2016)
Hey all,
Now, my questions:
Thanks folks!
Dan
Now, my questions:
Thanks folks!
Dan
2) You are correct - they do not need to be blocked if you replace the bolts.
3) Why on earth would you do that?
1) No. The stock breather bolts are too short. Well that answers that question. Thank you.
Cool.
3) Why on earth would you do that? Because the original install instructions for the backplate indicate torqueing down the breather bolts before the air filter mount studs. Didn't know if order would matter with a partial disassembly. Judging by your response here, the answer is no.
Cool.
