Go with New Map or Old Map SEPST
Ok, I was able to pull the map from my VCI that the previous owner installed. He said that he had it tuned at the dealer when he upgraded to SE A/C, Power Duals, Monster Rounds.
The map they loaded is spec'd for 2010-2013 touring with SE A/C, big bore cyl, flat top pistons, and race exhaust...same as described in map 044AAo003.
Pulled both maps to compare. AFR table is the same, VE and a couple other tables have differences.
On the loaded map there is nothing showing under Smart Tune and no difference in original vs working tables.
My question is as I am not sure of the level of tuning the dealer did (maybe they just dumped the map it and didn't dynotune...maybe they did a full tune??) should I use the previous owner's map as a base or should I use the 044AAo003 map? I am wondering if the map I have loaded is actually 044AAo002 which I think was the base map back in the day when they did the work and the 044AAo003 is updated as of 2014.
Thoughts? Thanks in advance!!
