Fuel tank quick connect leaking
Old 08-21-2016, 08:41 PM
cjgray's Avatar
cjgray
cjgray is offline
Default Fuel tank quick connect leaking
So my 2011 roadking is leaking gas out of the quick connect. If I disconnect it it doesn't leak. If I push on it it doesn't leak until I let go. If I pull down on it it just runs out until I push up on it.
Is there orings up in there I can replace or do I need to replace the whole thing? My dealer isn't open till Tuesday to get parts.
Sorry if this is on the site somewhere but I'm on my phone and it won't let me search the forum. Thanks in advance for the help.
Old 08-21-2016, 09:47 PM
skydude426's Avatar
skydude426
skydude426 is offline
When my wife's 06 started doing this I replaced the connector with attached fuel line in the tank and I replaced the fuel line that goes to the fuel rail on the throttle body for good measure.
cjgray (08-22-2016)
Old 08-21-2016, 10:11 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Yes there is an O ring up in the connector.If I remember correctly its the same size as your oil o ring on your drain plug.
cjgray (08-22-2016)
Old 08-21-2016, 11:22 PM
bagman1's Avatar
bagman1
bagman1 is offline
I dont think its the same size as the drain, its smaller and thicker. I tried to buy one at the dealer for a bike I was working on and they told me its not sold separately, you have to buy the line and fitting.
cjgray (08-22-2016)
Old 08-22-2016, 04:43 AM
just plain john's Avatar
just plain john
just plain john is offline
If that's true, you can buy an assortment of Viton O rings for far less than the line and fitting, but IIRC it is indeed the same size as the drain plug.
Old 08-22-2016, 07:09 AM
bagman1's Avatar
bagman1
bagman1 is offline
Im not sure what you mean by IIRC? I understand about finding an O-ring, I forget if viton is compatible with gasoline though.
Old 08-22-2016, 07:19 AM
ynots's Avatar
ynots
ynots is offline
I personally havent tried one but there are several treads saying to use a #41 o-ring.
Old 08-22-2016, 08:09 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
IIRC = If I recall correctly
Old 08-22-2016, 08:38 AM
just plain john
I have spare drain plug O rings, I'll compare them when I get home and post up
Old 08-22-2016, 09:04 AM
Duracell's Avatar
Duracell
Duracell is offline
Received 1,659 Likes on 581 Posts
I put an oil plug "O" ring on mine about 60,000 miles ago when it leaked. Haven't had problem since.
Quick Reply: Fuel tank quick connect leaking
