CAT history
Previous to 09 some models had cats in the mufflers - not the header.
09 Cat models were often sold in other States bordering CA- for instance Yuma AZ H-D stocks CA models so they can sell in CA and AZ, other dealers do similar.
The VIN will tell if a bike is a CA model- which will also be equipped with a vapor canister.
or you can tap the header pipe with a pen from the exhaust port down, you'll hear it tink tink tink, clunk.
when I was shopping 09 bikes in 2010- a large number of the bikes I looked at here in PHX had cats in the headers
USA 2010 introduced tier ii emission regs which required cat in all models and increase penalties for tampering.
OP your bike is probably an international model- check the vin.
& you can look up the part number stamped on the muffler
Mike
The (normally hairy and brown) beaver is our national animal in Canada - My other home is Thailand and I wonder what the Thai national animal is - most likely the same but black!
My Canadian bike is a WA model 08 Road Glide Police so no CAT?
Replacing them with 2013 mufflers so also no CAT?
Seemingly correct from what is posted here
Are the 08 and 13 muffler guts the same given that the 13 muffs had a CAT in the head pipe?
Presumably not and I wonder if the 13's have higher flow
One thing to look for is the stamp on the muffler. If it has a cat in it the stamp will show that. Some Dynas, Softtails and all Sportsters still come with the cats installed in the mufflers and not the headpipe. Another way to tell is just look in the inlet end of the muffler and you'll usually see the converter. And you'll probably wonder how any exhaust gas gets through that thing.
