neutral light?
Old 05-23-2007, 12:44 PM
kingultra's Avatar
kingultra
kingultra is offline
Default neutral light?
any one having problems with the light coming on when not in neutral? It seems to start after riding a couple hours (maybe when the bike is really hot)
Old 05-23-2007, 01:11 PM
Manish_Hawg's Avatar
Manish_Hawg
Manish_Hawg is offline
Default RE: neutral light?
New one on me....I've been in neutral and have no light and then it comes on later. The problem is: When you take it back to the dealer it's going to work fine.
Old 05-23-2007, 01:14 PM
glide's Avatar
glide
glide is offline
ORIGINAL: kingultra
I'll bet you just washed the bike recently, dry out the switch with some compressed air around the rim and warm it up too. The switch is not waterproof and when you hit it with a hose directly , it takes in water.
Old 05-23-2007, 01:44 PM
King FLH's Avatar
King FLH
King FLH is offline
I've read about that happening here to other riders with '07s. It's gotta have something to do with the heat affecting the switch.
Old 05-23-2007, 03:10 PM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
I had that issue, the neutral light coming on between all gear shifts up or down, it happened between 300 and 500 miles, but itdisappeared by the time I took it to the dealer for him to look at. Go figure.
Old 05-23-2007, 03:28 PM
lottinala's Avatar
lottinala
lottinala is offline
same problem different light, i had my high beam light doing the same thing for about 300 miles but as soon as i took it in to get it looked at pooffffff its gone to never return so what the hell i dodnt think about it anymore till i saw this tread now im going to think abot it again thanks
Old 05-23-2007, 04:58 PM
Dog's Avatar
Dog
Dog is offline
2nd Gear
Yes I did on my 07. It seemed to only do it when it got hot. I took it to the dealer and he put in a new neutral switch. 1000 miles later and no problem
Old 05-23-2007, 05:21 PM
Lost1's Avatar
Lost1
Lost1 is offline
Had a similar problem with my Glide awhile back- operation of the neutral light was intermittent. Turned out to be a loose connector on the neutral switch. Maybe the fix will be the same for yours.
The switch in question is located on top of the transmission, just to the right of the starter if you're looking down from the driver's seat. It looks like an oil pressure sending unit, and it has two connectors on top of it. Pull off the connectors, clean the terminals, then put them back on & make sure they are snug.Squeeze them a bit if necessary to get atight connection on the terminal. Problem with mine was one of these connectors was a little loose & was only making intermittent contact.
Could also beyour switch is bad.
Hope you get it figured out.
Old 05-23-2007, 07:02 PM
Iron Pony's Avatar
Iron Pony
Iron Pony is offline
Yup mine came on when the bike was hot.Three tries at the dealer but finally they replaced the switch now its ok.
Iron Pony
Old 05-24-2007, 12:50 AM
monkish's Avatar
monkish
monkish is offline
07 streetglide- happened twice. both times the bike was completely dry but was pretty hot. cleared up on its own and am having 5000 mile service done as we speak. if it happens again i will replace the switch.
Quick Reply: neutral light?
