What is the correct way to check oil level?
I apologize in advance for the newb question. I'm new to the HD world.
Just bought an '07 Electra Glide Ultra Classis with a 96CI motor. I'm still not 100% clear on checking engine oil levels. All I have read is to check it on the "jiffy stand" as HD calls it.
Should I be checking the level when the engine is warm or cold? I'm afraid I may have over filled it. I had changed oil and filter this weekend and added 3.5 qts of Amsoil 20W-50. It seemed a little low. I added a little more when it was cold and used almost 4 qts. The level was right on the top mark. After looking at the dipstick more closely(and now I'm beginning to feel like a dipstick ), I noticed it stated the top of the mark is supposed to be read when hot.
Suggestions?
Suggestions?
I copied this from the on-line 2007 touring owners manual
Oil Level Cold Check
Perform engine oil level COLD CHECK as follows:
If oil level is at or below the lower arrow, add only enough oil to bring the level to the middle of the two marks on the dipstick.
Oil Level Hot Check
Perform engine oil level HOT CHECK as follows:
NOTE:
The engine will require a longer warm up period in colder weather.
Do not allow hot oil level to fall below Add/Fill mark on dipstick. Doing so can result in equipment damage and/or equipment malfunction. (00189a)
Do not overfill oil tank. Doing so can result in oil carryover to the air cleaner leading to equipment damage and/or equipment malfunction. (00190a)
NOTES:
The engine oil dipstick has different markings on its two sides. Engine Oil Dipstick shows the engine oil level when the motorcycle is on its jiffy stand. Engine Oil Dipstick (Sidecar Use) shows the engine oil level with a sidecar attached (motorcycle upright).
For cold check level, do not exceed the midpoint (2) when filling with oil.
- For preride inspection, place vehicle on level ground and rest the vehicle on its jiffy stand (unless sidecar is attached).
- Turn filler plug/dipstick counterclockwise. Remove and wipe off the dipstick. Insert the dipstick back into the oil pan with the plug screwed completely into the fill spout.
- See Engine Oil Dipstick. Remove the dipstick and verify the level of the oil. The correct oil level should register between the two marks on the dipstick. If sidecar is attached, check oil level using the opposite side of dipstick as shown in Engine Oil Dipstick (Sidecar Use).
Oil Level Hot Check
- Ride motorcycle until engine is at normal operating temperature.
- Place vehicle on level ground and rest the vehicle on its jiffy stand (unless sidecar is attached). Allow engine to idle for 1-2 minutes. Turn engine off.
- Turn filler plug/dipstick counterclockwise. Remove and wipe off the dipstick. Insert it back with the plug screwed completely into the fill spout.
- See Engine Oil Dipstick. Remove the dipstick and note the level of the oil. If sidecar is attached, check oil level using the opposite side of dipstick as shown in Engine Oil Dipstick (Sidecar Use). Add only enough oil to bring the level to the FULL mark on the dipstick. Do not overfill.
NOTE:
Refer to Recommended Engine Oils. Use only recommended oil specified in Engine Lubrication.
- Start engine and carefully check for oil leaks around drain plug and oil filter.
NOTE:
- Check engine oil supply at each complete fuel refill.
- Refer to Regular Service Intervals: 2007 Touring Models. Oil should be changed at specified intervals in normal service at warm or moderate temperatures.
- Oil change intervals should be shorter in cold weather or severe operating conditions. See Winter Lubrication.
- ADD QT (lower) mark
- Cold check level
- FULL (hot check) mark
NOTES:
- Cold check level
The following 4 users liked this post by semiret:
ElectraJim (08-16-2016)
Yes needs checked good and hot. Believe the big book states to let it idle for two minutes on stand after getting it warmed up. I found it needs to be driven at least 20 minutes before checking. I've had to suck it out a couple times now.
Yes it needs driven at least 20 minute to get the true reading. Book states to idle couple minutes on stand, shut off then check.
The following 4 users liked this post by thealien:
