2000 RK Primary oil change
Guys: My neighbor has a 2000RK and he changes the engine & trans oil but not the primary (wow). So I am helping him do so because I have all the tools. Questions:
1. how much oil in the primary?
2. torque spec on the derby cover bolts?
3. does the clutch adjust the same way as a dyna?
4. torque spec on the drain bolt?
Any help would be appreciated......
RE: 2000 RK Primary oil change
1. how much oil in the primary? About a quart
2. torque spec on the derby cover bolts? Usea 1/4 driver and you won't have any trouble.
3. does the clutch adjust the same way as a dyna?Same way
4. torque spec on the drain bolt? Snug for transmission/crank, flush for primary drain.
