Help with wiring colors tbw 2015 ultra limited
My green connector broke while pulling the wires, so now I am going to solder them back together. Problem is I don't know which wires connect to where. I googled and found nothing.
I think the wiring may be different on 2014 and Up
Any help would be appreciated!
right now I am wired at:
BLACK SIDE
white to blue
black to black
red to brown
yellow side
black to gray
white to purple
red to red
throwing 8 different codes, check engine light, and no throttle
BLACK SIDE
white to blue
black to black
red to brown
yellow side
black to gray
white to purple
red to red
soldered joints do not hold up well on vehicles, you'd be better off to use crimps
when soldered, the wire strands flex where the tinning ends ( right by the insulation) this flexing will cause the wires to break- not tomorrow or next week but somewhere down the road
Mike
Mike
BLACK SIDE
white to blue
black to black
red to brown
yellow side
black to gray
white to purple
red to red
BLACK SIDE
white to blue
black to black
red to brown
yellow side
black to gray
white to purple
red to red
Blue Wire------(Black Side) White Wire
Brown Wire----(Black Side) Red Wire
Black Wire-----(Black Side) Black Wire
Grey Wire-----(Yellow Side) Black Wire
Red Wire------(Yellow Side) Red Wire
Purple Wire----(Yellow Side) White Wire
https://www.shop.harley-davidson-ros...s/56032-08.pdf Try this link first. Page 2 and 6. You may have damaged the sensor or the wiring while removing it from the handlebars. Worst case is you're out $100 for a new grip sensor. Unless, you have a different issue. You would normally throw 3 codes if your grip sensor was not working properly. What codes do you have right now?
P1510 - Throttle actuator control limited performance
P2127 - Twist grip position sensor low/open
P2138 - Twist grip position sensor correlation error
