Sensibility of throttle by wire in bumps
I hate my throttle by wire, when i ride on a rough road and hit bumps and hole, the slightest movement of my wrist give me a jerky ride , the feeling is very bad compared to standard throttle...
Am i the only one with this trouble ? Dealer said everything is fine
Received 1,639 Likes
"Sensibility"
I also hated it. Even after several thousands of miles of riding, thinking I will get used to it and adjust accordingly. I read that a tune will eliminate or minimize it. I recently installed cams and am using a PCV with a canned dyno map. The over sensitive tbw feeling is gone. Some have mentioned that the tbw sensitivity can be adjusted with tuners - TTS...
Harleys are hardly crotch rockets. Can't help but wonder what previous bike the OP rode for comparison. In what gear is this happening? The lower gears are certainly more sensitive to small throttle movements. I have learned to try to avoid the bumps and if that isn't possible, I coast through the worst parts with the clutch lever pulled in.
