What's Up With Rineharts ?
RE: What's Up With Rineharts ?
Bubs (530-477-7490) will replace the end caps for the original owner within a specific period of time...can't remember the exact time right now. I got them to admit that they have a problem and that even the replacements will change color over time. The CS person told me it is due to UV.
You can buy replacements, new take offs, on e-bay. The prices are all over the board. I paid $40 for a new set. I have seen them go for over $100 a set.
Good luck,
RJ
Good luck,
RJ
ORIGINAL: Rocket Jockey
Good luck,
RJ
Good luck,
RJ
Yea, i had mine turn red within the first 1000 miles. 07 UC with racer tuner, eaglebeaks RHs, Dyno'd before i picked the bike up with like 5 miles on it.
I called Bub and they advanced shipped me one. i just managed to get the bolt out (ended up cutting a flat head in the allen head to get the damn bolt out but worked like a champ).
I would have to say that mine is from the extreme heat from a bad tune. The end cap was getting over 450 degrees, at the end cap!!!!....I dont believe it is only a UV issue as one stated above after speaking with the BUB CS. If that were the case, then both of mine would have changed.
After a good ride, I can grab and hold the left pipe... can barely get close to the right end cap before feeling the high heat from the endcap.
This really doesnt seem to be a BUB issue to me. If Harley wasnt screwed on the EPA regulations, their (BUB's) product wouldnt be failing. Right? But that just goes back to HD selling a product they knew had issue from the regulations but still produced the product the same way they always have, passing the "buck" to their customers.
I had to spend close to 1200 bucks to correct the "regulations" issue HD released in their product.
Dont get me wrong, love my Harley.. just sucks to walk out to your brand new UC and see the entire length of the pipe blued and pitted from the extreme heat....
/semi-rant off.....
/semi-rant off.....
have about 4k on my RH TDs ... seem to be jet black. I try to actually keep my RPMs up so as to keep the exhaust pushing out at a good rate and not lugging. Work great...sound great...and look great.
The 'red' or copper/orange colors ... (even saw a post about the chrome tips turning GOLD) .... I would bet dollars to donuts it has more to do with the heat than anything else. I see Lenrough's tips. One black the other orange. .. strange only one is turning. almost wondering if the #1 cylinder is running lean and running hot.
