Alloy-Arts TXR or RideStra8 Opinions Please
Hi All, I'm in a quandry. I'm in the market for a stabilizer and have narrowed my choices down to the TXR and Ride-Stra8. I have talked to Dan at Ridestra8 and also with Rob at Alloy-Art. Both make excellent arguments for their product. I'm convinced by each but can only use one on my SG.
At the moment I think the edge is going to Alloy-Art. Their product is $100 less expensive from M&M and it looks more sturdy than ridestra8. IT also has vents for airflow to cool the transmission and will not hinder clearance as does another competitor, Tru-Trac
I know that RideStra8 doesn't cover the Trans at all but to me, it doesn't look as sturdy.
At this point I think my final decision will come from users on this forum.
Please let me here from those using these products.
Thanks,
Frank
Ridestra8.com
alloyart.com
Thanks,
Frank
Ridestra8.com
alloyart.com
RE: Alloy-Arts TXR or RideStra8 Opinions Please
My RideStr8 has only been on a couple of days, but so far it's done the job. That TXR is quite the work of art.
See my post https://www.hdforums.com/m_1667907/m...tm.htm#1667907
I have the txr and I don't like it. One good curb loaded down will probably take it out, it hangs a good 3/4 inch lower than the cross member. Also for it to work you have to have it tight, and when you do it shakes like a old softail because its trying to stop the motor from moving in it's mounts. Stick to the proven products, true track or ride st8, the txr is a over engineered POS IMHO. Mines comin off and a true track is goin on.
ORIGINAL: rideon
If you are going to rethink, consider the RideStra8. It's a totally different design.
Keep in mind, all stabilizers will present vibration if not adjusted properly.
ORIGINAL: Streetrunner
Rideon, You say you are going with the tru-trac because you think it will give you more clearance and less vibration than the TXR. I'm thinking you should rethink that idea. The TXR is very similar to the Tru-trac. It was designed from it. The Tru-trac will definitly drag in right hand turns, the TXR will not. The TXR is vented to help keep the trans cool. The Tru-trac bolts tight to the trans and will not allow heat to excape.
ORIGINAL: rideon
Well I have the TXR, and I also have a lowered bike (actually ride it quite low in the rear with the Platinum air shocks). And after my little test ride, the bumps, railroad tracks, and other things I have riden over and around; there is no way that you are goig to rip the TXR out from under the bike, UNLESS you totally suck as rider (purposly hitting all afore-mentioned items). The bumps and potholes you are goingto thave to hit would most likely un-a$$ you from the seat before you would even worry about ripping the TXR out.
Anyway, I have a post about the TXR and my experience with it. Granted it's only a 60 mile ride, but in that 60 miles, I wanted to make sure the TXR was going to do it's job.
ORIGINAL: Gaskett
Well, I could see you might have a problem 2 up, fully loaded and some speed bumps. Never really considered that since I don't really do that type of riding.
So, you have a point, it could hit in that situation. It does hang a total of 3/4" of an inch below the crossmember (that is too the lowest point onthe stabilizer.
Glenn
Glenn
ORIGINAL: Gaskett
Glenn
Glenn
AdrianVall
04-06-2009 10:41 AM
AdrianVall
02-17-2009 02:26 PM
