ultra not charging?
Old 08-09-2016 | 02:08 PM
ldepatie's Avatar
ldepatie
so without looking at it yet cause im at work still where is the volt meter(one on dash)hooked too?
Old 08-09-2016 | 06:38 PM
Jackie Paper's Avatar
Jackie Paper
Three wires on a 2014... Red goes to battery fuse (voltage read). Black/Green is ground. Violet/White goes to the IM to the HD-Link Output connection (that is what throws the low voltage light)
Old 08-10-2016 | 07:34 AM
ldepatie's Avatar
ldepatie
ok I probed the stator and have 30 volts on all three leads so I believe the stator is fine correct? I also ohmed it to ground and no short there
Old 08-10-2016 | 07:56 AM
Jackie Paper
You are a little low..maybe fine for idle. What was it at 2000 RPM. That is the test standard since it varies as rpm goes up.
Old 08-10-2016 | 08:02 AM
ldepatie's Avatar
ldepatie
yes it was at idle
Old 08-10-2016 | 06:02 PM
ldepatie's Avatar
ldepatie
ok good news everyone I replaced the regulator and everything is working as should again I still think harley should of replaced it they had a recall on some 12 models but mine didnt fall under the recall but yet they sold me a upgraded regulator oh well at least my complaining got me 10 % off the new one! thanks again for everyones help
Old 08-12-2016 | 09:33 AM
Chris Meek's Avatar
Chris Meek
4th Gear
Great postings, and a lot of help. I have a question. Last week, I got home from a 2000 mile ride, in the last 50 miles, I hit a downpour, rode through it some. After drying out, my voltage meter started the going up and down with the check engine light and battery light coming on. I ran the diagnostics and the High Voltage, Low Voltage codes showed as well as over charging and under charging components.
I changed out the Voltage Regulator, tested the system and it idles at between 13.9 and 14.1 depending on when I test it. However, it doesn't go much higher when throttled. Should I be concerned?
Old 08-12-2016 | 12:45 PM
Jackie Paper
You need to go the the control panel in the forum and create you a signature at least what your bike is.... year model code letters.... No one can answer that without know your system. For all we know, you have a Trek Moped.
Old 08-12-2016 | 02:21 PM
ORradtech's Avatar
ORradtech
As a general rule battery voltage, tested at the battery terminals, should be right around 14.2V at 2000 rpm.
Old 08-14-2016 | 03:10 PM
ILMChris's Avatar
ILMChris
Stage IV
I have 2012 FLHTCU Ultra Classic
Quick Reply: ultra not charging?
