Cutting open an oil filter
Old 08-06-2016 | 08:34 PM
cajun1957a's Avatar
cajun1957a
Default Cutting open an oil filter
I want to cut open my oil filter to look inside for those little orange pieces of chain tensioner. What is the best way to do it? hack saw or cutting wheel and which way?
randy
Old 08-06-2016 | 08:49 PM
crimson13's Avatar
crimson13
Can you cut the ends to get to the filter media?
Old 08-06-2016 | 08:55 PM
cajun1957a's Avatar
cajun1957a
yes I can do that. Do I need to cut both ends
randy
Old 08-06-2016 | 09:05 PM
jammerx's Avatar
jammerx
I used to use a tubing cutter and just cut below the top ( the end you screw on ) if you use a saw or a cut off wheel then you will fill the filter full of metal and not be able to tell where any of that came from?
Old 08-06-2016 | 09:13 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Years ago I went to school with a red headed buck toothed dude that the teacher once had Him stand with His nose in a circle on the chalk board. He gnawed a hole thru the chalk board all the way thru to the bricks. He could take care of that filter for you.
If I can find His phone number, I'll forward it to you.
Old 08-06-2016 | 09:36 PM
soos's Avatar
soos
Can you post it here? Being a machinist, I've cut oil filters open using my band saw, but that dude you know could definitely do a cleaner job. I am really interested.
Old 08-06-2016 | 11:34 PM
dkstuck's Avatar
dkstuck
summit racing has a nice cutter for under $40.
Well worth it if you going to check your filters! BEWARE of first filter you check, (I've only done auto so far) Scare the crap outta you with junk in media!
Old 08-07-2016 | 12:15 AM
SamStone's Avatar
SamStone
Hacksaw. Save your money. I used to drain my oil through a sifter also, before I upgraded to the new hydraulic tensioner so.
Old 08-07-2016 | 06:43 AM
xcbullet's Avatar
xcbullet
Chisel
Old 08-07-2016 | 07:46 AM
RKZen's Avatar
RKZen
Laser gun, cuts clean. Or tin snips.
Quick Reply: Cutting open an oil filter
