Add Power Inside Saddlebag
What I plan on doing is mounting a 12v usb socket on the inside of the bag, drill a hole with a split grommet to run the wires through and connect them to the battery. Once it's mounted, seal up any gap in the grommet with some rtv. Something like this. I figure 3M auto body molding tape will hold it in place well. If not, I will make a flat piece of metal to slip behind the bag retainer, and connect it to the screw holes of the usb bracket.
Bville-Bud (08-06-2016)
I have used Powerlet.com products for years.
I have been contemplating this myself.
This one looks interesting and probably the one I will use.
http://www.powerlet.com/product/tank...ector-only/286
Here are more options.
http://www.powerlet.com/shop-by-prod...et-kits/SKTKIT
That is the one I'm thinking about. I have a tank bag on another bike with thta connector and like it. I was just hoping to hear some input from others who have done it. Will likely buy one next week.
I used the Harley saddle bag power outlet.
It's meant to hook into the battery tender charging port. But I wired mine directly to the battery so I didn't have to keep hooking up and switching when using the battery tender. Then I added a weather pack connector just outside the saddle bag for easy removal of the bag.
http://www.harley-davidson.com/store...ary-power-port
Here's the pdf and it looks like it plugs into the battery tender outlet.
https://www.summitracing.com/parts/a...FcSCfgodaAYMTw
