Electronics on bike quit
We just took a 1800 mile trip from IL to UP and northern MI, bike performed flawlessly. ON the way home, like the last 60 miles my cd player started acting up and the cruise quit, wouldn't activate. I shut the radio off so just the time displays, then the time disappeared and I rode on home. got closer to home and realized the blinkers weren't working either, didn't flash.....wasn't for sure on the headlights. pulled in driveway, headlights on, turn signals lit up, no spotlights (have Headwinds spot/turn led combo).....unloaded bike, plugged into battery tender that night and next day everything was back to normal.
Ok, so I checked voltage regulator, putting out 14 volts with bike running, pulled battery, took to O'Reilly's and they showed it good. battery is 3 years old.
What's your opinion.....regulator having intermittent issues?
ORradtech.......don't know how to pull a diagnostic code? I cleaned every connection at the battery and reinstalled it, covered connections with petroleum jelly. It fired back up.....guess I will see if it happens again, if does I'll have to call my dealer for help, I'm not that smart.
As long as you're cleaning and tightening wires it's a good idea to do the other ends as well.
Somewhere on this site is a how-to on pulling codes. Not hard to do, just a process to follow. Offhand though I don't remember where to find it. Maybe someone with a better memory can help point you in the right direction.
Bdhouse61 (08-05-2016)
