heel toe shifter issue
I have a 97 electra glide classic. the last couple weeks been having an issue with the heel shaft coming loose during riding. Bought a new set of heel/toe shifter thinking maybe the old one weren't any good. My second time riding with the new ones the heel came loose again. Could it be time for a new shifter shaft??
Yes, take it apart and inspect the splines.
Good Luck
Bill
http://partsfinder.onlinemicrofiche....TER%20ASSEMBLY
Good Luck
Bill
Received 1,939 Likes
I had a similar problem but with an aftermarket H/T shifter by Drag Specialties, which I installed myself.
My splined shaft has an ident ring milled into it so I had the new shifter body drilled & tapped so a set screw could be inserted through the shifter body into the ident on the spline. Its loctited in place and nothing budges now.
All in all its a cheap, effective fix.
