Loose left muffler
Loose left muffler
Had slip ons installed and now I've noticed while cleaning bike today that my left muffler is loose. Not a lot but definately not snug. Getting some side to side and up and down play where it attaches to the rubber mount on the saddlebag guard rail. Right muffler is snug. Do I need a new rubber mount insert? Started it up and noticed how much more the left saddlebag shakes compared to the right.
RE: Loose left muffler
I checked the bolt on the front clamp and the bolts where it attaches to the sadllebag support rail bracket. All are tight. I pushed the rubber mount forward with my finger and wa-la it snuged right up. Seems to me, and I am no mechanic, that the rubber mount on the saddlebag support rail bracket is stretched or worked it's way out of position.
My other theory now is that when I pushed on the rubber mount, I pushed the entire muffler forward. If that's the case and the clamp will not tighten anymore, I guess I should probably get a new clamp.
Check the clamp position. I had some work done to my bike and when they put it back together, they pushed the clamp too far up on muffler and covered part of the muffler where there is no slot. Loosen the clamp and slide towards the end of the muffler and retighten. This may do the job just fine. The rubber mount is for support and vibration dampening, and should last a long time.
Hopes this helps!
Hopes this helps!
The clamp has to be located over the slots at the end of the muffler or it will never tighten right. If doing that puts it someplace where you don't want it, you can loosen the bolts at the back bracket and it has some adjustment capabilities. Also I have had the rubber shrink at the back bracket and caused a squeak during idle. The only way I could make it go away permanently was to replace the rubber.
Dalejb is right, the clamps need to be over the slots at the end of the muffler. The further the clamp is away from the end of the muffler the harder it will be to tighten it with the result of not having the end of the pipe completely tight, therefore, causing pipe slippage. I had the same problem when I purchased my V&H slip-ons. After them slipping 3 times and me retightening the clamps 3 times at different intervals I realized that the clamps V&H sent me were not adequate for keeping the mufflers tight on the pipes. I went to my local indie shop and bought some heavy duty clamps and now no more slippage. You would think that after spending that much money on the V&H mufflers they would at least send you good clamps!
