2016 Street Glide - Keep my head pipe, or whole new system?
Aftermarket pipes are cool, no doubt. After discussing this topic on Harleytech talk, for a low end build say up to 130h/p, the stock decatted headpipe is very close in power output.
The guy that dyno tuned my bike, said same. A good 2/1 would not increase power significantly......
That is all......
That is all......
That is all......
That is all......
I think what this member is saying is,, if you like the look of the stock header pipes,, after it is decatted, it will perform as much as needed compared to a lot of aftermarket headers .... And he seems to have some physical dyno time to show this .... With the later models with the ox sensors down near the cat, I believe we are being bamboozled with science regarding cross talk etc,,, and aftermarket marketing to think our bikes will perform badly with a decatted stock header pipe.... I sure as hell dont have any problems with decatted pipes on a touring bike ,, and I have done a few ..... It comes down to money ,, looks ,, and time you have ,,,,
If you want to change the air cleaner for a new look, that is OK, but not necessary. Just
add K&N replacement air filter part #HD-1614 it will flow all the air a Stage-I needs. If
a Stage-I is all you plan on doing, then a good set of slip-on mufflers & a de-catted head
pipe work well with your plan. Check with Forum Vendor FuelMoto for a full system if you
go down that road. Good Luck
hAkron (07-31-2016)
I did slip ons and the V&H naked air cleaner.Im keeping the stock head pipe.Im not feeling the heat others are I guess.I had a pair of Night sticks in the garage from my road King and I bought a used air cleaner kit.Slip ons cost me $225.00 and air cleaner $105.00
I'm also keeping the cat in to tame the exhaust a little.Just my two cents.
I have a fuelmoto backing plate simply because I don't trust the plastic crap from the factory. From what I have read and what I witnessed when I took it apart a K&N in the factory housing is going to flow more air than a stage one bike can handle.
I only put my stage one filter on last night and put 20-25 miles on it and it,felt a little more responsive on excelleration.Might be to soon to tell.Isnt much loader then stock.Ill have to put a weekend worth of riding in it to be sure.I also got to try out a new seat at the same time.A P52164-10 is a comfy seat.
Mr.Softy
13
06-25-2015 02:55 PM
