5v Hardwiring for SiriusXM Question
I bought one of those SiriusXM Radio 5 Volt Hardwired Power Adapters that TSS Radio and many others sell so I can use my SiriusXM radio on my Electra Glide Classic (see picture) What I want to know is where to attach the tinned ends to get power. I realize that I want to attach to somewhere that is switched power so when the bike is off, so is the adapter. Honestly, the rest is now gotten confusing. Can anyone who has done this give me some clear cut directions on how to do this cleanly and safely? Of course, the directions that is came with are vague and sketchy at best...
Also the auxiliary plug under the seat is already in use for my Road Zeppelin seat so that route is out.
Thanks!
John
Thanks!
John
I use this ORANGE wire for signal to turn my amp on and for the UltraCool oil cooler fans (UltraCool instructions).
Ah ha, Gotcha. Is this wire combination easy to locate after removing the headlight assembly? Just for clarification: these wires only have power when the key is on, correct?
Yea, remove the outer fairing and look at the headlight wiring. It is obvious. You may have to open the wire loom up to see the wires.
No. I meant to tap the wires that feed the cigarette lighter socket. The wires behind the inner fairing.
There's no particular reason not to go to the accessory plug under the seat even if it's already being used for something else. That adapter just isn't going to draw that much current.
But the other two options in the faring would also work. And you could always tap into the radio power wire.
