Changing brake pads with ABS
Is there any difference in the procedure when changing out front and rear brake pads on a 2013 Limited with ABS vs Non ABS. I have a 13 Ultra without ABS and its simple but my buddy has a Limited with ABS and no he dosnt have a service manual and yes i know he should have one since i have told him he should but i was just curious since a buddy told me in discussion the other day that its the same procedure. im not to sure.
As a general rule on ABS brake systems, you want to crack the bleeder when pressing the caliper pistons back. The idea is to eject the fluid in the caliper instead of pushing it back up the line. The reasoning is that if there is any contamination, especially particulates, you don't want that pushed up where it can get into the abs module.
You don't 'need' to, but as some replies show, some people take the opportunity to do so when they replace the pads, myself included, and cycling the abs unit with the ignition switched on its the only difference I know of.
Why you'd switch the ignition on when bleeding brakes is another question, but hey, chit happens.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
