Properly bleeding ABS brakes... what's the cheat?
Old 07-23-2016 | 02:45 PM
finespun automation llc's Avatar
Default Properly bleeding ABS brakes... what's the cheat?
Anyone got a workaround for properly bleeding the ABS system without using the dealer?
Aviator5456 (06-09-2019)
Old 07-23-2016 | 03:11 PM
texaswiz's Avatar
texaswiz
Well, the cheat as you call it is to not let the brake fluid reservoir go empty as you are bleeding the lines. I have used a Mity Vacuum pump to do my ABS brakes 4 times over the years and I never let the reservoir run empty when adding fluid. If you do let it run empty you will likely let air into the lines and you will end up at the dealers with a bill for a session on their Digital Technician to reset everything. I put the brake fluid into a plastic ketchup squirt bottle to keep adding fluid. Cover up your gas tank with a piece of plastic because no matter how careful you think you are going to be, you will probably spill some. Oh ya, the cap on the reservoir will tell you what kind of fluid to use. Good luck.
Old 07-23-2016 | 03:51 PM
lp's Avatar
lp
The "cheat" or trick is to not turn the bike on while you're bleeding so the ABS unit does not initialize and cycle air into the valves.
Bleed the brakes as normal.
The following 2 users liked this post by lp:
Rusty Dailey (04-04-2023), slippin_jimmy (08-16-2023)
Old 07-23-2016 | 04:27 PM
sixguns's Avatar
sixguns
I bleed my own.
Old 07-23-2016 | 04:44 PM
Cousy's Avatar
Cousy
Agree with all of the above - MityVac and don't turn on the key while bleeding.
Old 07-23-2016 | 05:01 PM
Gunnysgt's Avatar
Gunnysgt
I've bled ABS brakes a few times when installing longer brake lines. All seem to go well and no ABS light staying on, but you know what, I still took it to the dealer for 1/2 hour labor cost and had them run it on the digital tech. IMHO brakes are nothing to be fooled with and you don't want to find out you should have done that while in the middle of an emergency stop and TBone, and find out the ABS failed. I figured the insurance of $40 was well worth it.
The following 3 users liked this post by Gunnysgt:
Goose_NC (04-05-2023), tbrince (04-02-2023), Wharf Rat (07-27-2016)
Old 07-23-2016 | 05:02 PM
ORradtech's Avatar
ORradtech
As long as you don't introduce air into the abs module your brakes will bleed the same as non abs systems.
It's as simple as that.
Should you mess up and let the reservoir run dry, that's when you need to take it to the dealer to have the abs bled.
Old 07-23-2016 | 06:26 PM
Sam2010's Avatar
Sam2010
Local dealer here quoted $100. For a brake fluid flush. It was commented that Harley is starting to consider it a safety item.
Old 07-23-2016 | 06:45 PM
beary's Avatar
beary
I believe the cheat is to replace the fluid with a mityvac, ride the bike and brake hard enough to cycle the old fluid out of the ABS, then replace the fluid again with the mityvac to remove the old ABS fluid you just cycled.
Might be worth $100 to let the dealer do it.
Beary
The following 2 users liked this post by beary:
2011FBL (06-20-2021), tonyd2017 (04-06-2023)
Old 07-24-2016 | 05:10 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
I bleed the brakes normally with a clear tube and a wrench, adding fluid as needed (after soaking out the old fluid in the master cylinder with a clean rag).
Then I go ride the bike and cycle the ABS and flush the lines again. I do this once a year in my ABS bike.
As mentioned, do not turn on the ignition during the process.
Quick Reply: Properly bleeding ABS brakes... what's the cheat?
