Properly bleeding ABS brakes... what's the cheat?
Old 04-02-2023 | 04:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Yes, you are right.
  #62
Old 04-02-2023 | 04:18 PM
M Oclaf's Avatar
M Oclaf
I read you will feel levers pulse. I have had numerous fast stops, but not sure if they rose to level of needing ABS since I just bought the bike.”
Never read anything about pulsing, I do know I have heard the ‘click, click’ of the ABS unit. One will not notice the ABS working.
  #63
Old 04-02-2023 | 07:42 PM
Rounders's Avatar
Rounders
Originally Posted by M Oclaf
I
I have seen that in videos with the bike off and flushing with scanner. But would you hear that when riding? I have read some say you will feel it in the pedal or lever if activated. Which makes sense some.
I have less than 2k miles on this bike. to my knowledge I have never needed ABS. Went for a ride today non abs bike, and did not come to a skid either. Hundreds thousand miles will go by without locking up brakes
  #64
Old 04-03-2023 | 09:52 AM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
It’s easy enough to find out. Ride your bike, jam on the brakes so the abs engages, see if you feel or hear it.
It’s not a bad idea to know this, so you can tell if they are engaging in normal riding. Which would let you know you are overriding the conditions.
The following 2 users liked this post by foxtrapper:
kel03 (04-03-2023), Rounders (04-03-2023)
  #65
Old 04-03-2023 | 01:05 PM
CoolBreeze3646's Avatar
CoolBreeze3646
If you 't answer the question, or discuss ABS, why post? You guys got a crush on me. Having groupies is not as much fun as I thought it would be.
What ever you say roundabout.
ybnorml (04-03-2023)
  #66
Old 04-03-2023 | 01:20 PM
Rounders's Avatar
Rounders
What scanner you using when you service and, if you have abs?
  #67
Old 04-03-2023 | 01:30 PM
CoolBreeze3646
I have a 2019 FLHTCUTG with ABS, Traction control and the other BS nanny stuff. Thought about buying a scanner; however, not cost effective for me as it would be once every two years.
I have enough other auto scanners, VOMs, and testers in my tool box that I do not need another one laying in there that will get minimal use.
I flush and bleed the brakes, then take it to my dealer who cycles the ABS with the HD Digital Technician, then run what is left in the brake fluid can through the system.
Dealer charges me 15 minutes of labor ($35.00), service manager said it takes them longer to hook it up than to run the ABS cycling procedure.
Have a long and good relationship with my dealer and they know I work and maintain my bike to HD standards.
  #68
Old 04-03-2023 | 01:52 PM
jimglassford's Avatar
jimglassford
The dealers here will not do anything for less than an hour fee.
  #69
Old 04-03-2023 | 02:41 PM
Ultra103's Avatar
Ultra103
I use the ITM HD2 tool. Quick and easy.
By the way, as has been mentioned before, anyone who has ABS and hasn't experienced it, get up to 30 - 40 MPH without anyone behind you (big parking lot or back road) and jam the brakes on HARD. You'll experience the amazing braking possible with your Harley AND learn some skills that could save you some day.
These big 'ole pigs stop in a HURRY in a straight line under hard ABS assisted braking. It's a great feeling.
itsdug (10-06-2023)
  #70
Old 04-04-2023 | 09:21 AM
ohioflhs's Avatar
ohioflhs
I think the cheat you are looking for is to bleed as normal. Then I exercise my ABS on a gravel road. This should change to fluid in the abs module.
Quick Reply: Properly bleeding ABS brakes... what's the cheat?
