Power Vision PV-2 Map Questions
Old 07-26-2016 | 02:23 PM
heavypic's Avatar
heavypic
Semiret,
I just saw your reply about doing shorter autotune runs.
I did an autotune run Sunday for about 50 miles. I did a mix of rural cruising, small town red-light stop-n-go and interstate, trying to cover as many bases as possible. After the autotune run, the VE table on the PV-2 screen was well-populated in the RPM ranges I customarily ride. All cells showed 'hits' in those RPM ranges...in other words, there were no non-hits in the RPM range that I was riding.
I'm certainly no expert at this. I flashed the autotune changes to the ECM, and rode another 20 miles. The bike rode well...very responsive, and no misses or decel pops.
This was a 'stock modified' map/tune from Dynojet. It's temporary until I get the new exhaust, and a corresponding new map. I will then autotune the new map. I'll try the shorter autotune runs as you suggest.
Thanks again...
rsking45
03-28-2016 11:58 AM
Celphish
07-19-2015 05:49 PM
polbit
2014-2023 Touring Models
43
04-28-2015 09:24 PM
SpicOfTheDevil
02-10-2015 09:53 PM
LKHA
02-27-2012 08:14 PM
Quick Reply: Power Vision PV-2 Map Questions
