120R in a 2000 RKC?
Old 07-22-2016, 11:44 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
Default 120R in a 2000 RKC?
Can it be done without modifying the frame?
Old 07-22-2016, 03:26 PM
MilesOfTexas
I guess this was a dumb question. Only asked because I can't seem to find anything that says one will fit that year/model. I know they will fit '09 and above.
Old 07-22-2016, 03:53 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
You should talk to S&S or R&R cycles. Similar cost better value. I have a 120R, its awesome in a 12 frame but for a 07 down frame i would go S&S 124.
Old 07-22-2016, 04:14 PM
MilesOfTexas
Thank you for the recommendation!
Old 07-22-2016, 09:21 PM
bigskyroadglide
Sorry, i failed to answer your question. I have not seen a 120R installed in a HD touring bike with external oil lines such as those present on the early twin cams up to 06. Maybe someone else has, i have not. Seen a bunch of S&S motors in those frames.
The 120 should fit 07 up in its present configuration
Old 07-23-2016, 12:25 AM
lh4x4's Avatar
lh4x4
lh4x4 is offline
They will lfit 07 and up. The one exception is the 06 Dyna with the six speed. The 120's only bolt up to 6 speed.
I put a 120 in a 13 Street Bob and a 15 Freewheeler.
I choose the factory built 120's over a S&S as the dealer you buy it from puts it together. Last year on the Dyna forum a poster did a 124 build. It progressed with pictures until it was together. Then it was dyno'd and blew up. The guy still posted that the engine was going to be torn down and the cause identified. No more posts I suspect that the builder had a signed document that he was not responsible for what happens on the dyno and the buyer never got a running engine.
I have over 10K on the engine in the Freewheeler and 3K on the Dyna. They have performed faultlessly and with awesome performance. I know on bagger with over 30K on a 120.
If it goes into a throttle by wire bike you choose between a 58 or 64 mm intake manifold. If it goes into a cable throttle then there is a choice of a 58 or 62 mm intake. Either way then you select a type breather and size of injector.
Old 07-23-2016, 07:46 AM
bigskyroadglide
You like the R or the ST better? My R required a cam change to perform well below 3K RPMs as the 266E did not like running at 2500 to 2800 rpm.
The 259s in the ST supposedly are better but ive never ridden a bike with a 259 cam
The S&S 124 comes with a 1 year warrenty like the 120ST and it can be purchased as a complete engine, in a LC or HC configuration
www.sscycle.com/search
My 120R has over 10K and has performed flawlessly after a cam and lifter change
Old 07-23-2016, 08:38 AM
lkr0's Avatar
lkr0
lkr0 is offline
S&S 124 crate motor - built at the S&S factory - with at least a one year warranty - and if you ever dicide to go bigger the S&S platform can take it -- best crate motor you can buy -
bormand85
01-03-2018 10:43 AM
rebar490
05-04-2014 02:12 PM
BOCR6
07-29-2012 09:08 AM
story808
03-04-2011 03:48 PM
MetalSpine
03-19-2008 07:40 AM
Quick Reply: 120R in a 2000 RKC?
