Burly slammer and stretched bags
Old 07-21-2016 | 10:55 AM
stbobshadow's Avatar
stbobshadow
Default Burly slammer and stretched bags
Any issues with using the burly slammer kit with stretched bags? Also were the front springs hard to install? Going on a 2012 street glide.
Old 07-21-2016 | 12:07 PM
Sturgis67's Avatar
Sturgis67
which front springs? drop in kits are easy, pull the caps, cut the spacer, drop everything in and recap. standard lowering kits require the fork legs to be removed.
Old 07-21-2016 | 02:13 PM
bikerlaw's Avatar
bikerlaw
What bags? 4 inch, Screamin Eagle tapered, 6 inch. Slammers are basically the worst possible suspension option in terms of comfort, but that aside, I suspect you will shred pretty much and saddlebags longer than stock length with slammers. Well, if you try to lean into a turn with any vigor.
wv14streetglide
10-30-2016 09:52 PM
smithmx47
03-31-2014 05:04 PM
vtdiesel
10-03-2013 03:11 PM
coop57
01-27-2009 07:51 AM
Toolguy
09-03-2008 09:56 AM
Quick Reply: Burly slammer and stretched bags
