Dam exhaust bracket rubber bumpers
I've never lost one, had them start the dreaded squeak and replaced them but I've always found them to be tight or didn't feel like they would ever fall out.
I'm guessing the rubber shrinks up over time maybe?
The wire tie idea seems legit but I don't think it'll keep them from squeaking, or maybe it will. Lol
OP
I got a '14 RK with about 8K miles. I started getting a noise from the left side exhaust. I checked all bolts/straps...everything was tight but still squeeked. I suspected a loose baffle in the muffler because the noise stops when I grab the left muffler. The rubber bushing is indeed a loose fit on the left side vs the right side.
Went to the dealer for the recall for bags falling off. While there, I asked about the noise. They said I could replace the rubber bushing with the type used for the trikes which they claim is a tighter fit.
I'll probably cut a piece of thin rubber or use a neoprene/rubber-type washer in there to take up the slack.
ok. i just checked them good. the left one never came loose or slid out. i looked at the right side and sure enough if u look close, there is a front and back to the rubber piece. i flipped it around. there is a little rubber nub on the front that looks like it catches on the metal bracket to keep it from vibrating out. mustve put it in backwards when i pulled off the mufflers. will c if it stays put now.
