Brake Fluid........sorry to ask
Old 07-21-2016 | 07:31 AM
GRWHD's Avatar
GRWHD
Originally Posted by Retrop
I think I would defer to whatever was printed on the master cylinder cap.
That is not always the case.
A buddy has a Buell, it is marked incorrectly....
He was having all sorts of brake problems after changing fluids (if I remember correctly it had to do with Brembo rubber parts) .
Did some research and found out it was marked wrong.
Flushed and replaced all the rubber parts of the system and the brakes work great now.
Old 07-21-2016 | 07:40 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Originally Posted by foxtrapper
A 2004 should be DOT 5 silicone fluid, I don't think there's anything special about a Custom that would cause it to be using anything else.
Here's how to tell if what you have is silicone (DOT 5) or glycol (DOT 3,4,5.1):
Take a drop of the brake fluid and drop it into a cup of water. If it mixes and disapears, it's glycol. If it does not mix, it's silicone.
This is so on point to what the OP is trying to find out that it should be quoted.
OP this ^ is the answer to your question. It'll take 2 minutes to figure out and it'll take 2 hours to rebuild the master cylinder and caliper(s) if you introduce silicone fluid into a glycol system or vice versa. As far as flushing lines and going from one to the other? Not me, without a complete rebuild of everything including lines. A frozen caliper because of the eventual goo isn't on my list of things I'd like to do.
Old 07-21-2016 | 07:52 AM
head's Avatar
head
When i bought my bike used, it only had 8000 miles on it. But when they were adding some chrome pieces to it, they added a chrome front master cylinder cover and bought the wrong one as far as which fluid it used. I wouldn't imagine that someone had the wrong stock one on the op's back, but stranger things have happened.
Head
Old 07-21-2016 | 07:56 AM
bagman1's Avatar
bagman1
I flipped an 04RKC a couple years ago and it came with dot 5. I disagree where someone said dot 5 will turn a straw color, thats dot 4. Dot 4 looks more like a vegetable oil or has a yellowish tint. Dot 5 is a purpleish color when new, and turns black when dirty. Ive done a conversion before on a bike but I used an engraver and made a 4 over the 5 after replacing everything when I did the conversion. Person didnt want to buy a new cap.
Sounds like your rear is original and the front has been compromised. Youre between a rock and a hard place, knowing it is wrong and now you have to do it right.
Old 07-21-2016 | 08:08 AM
zz2h33's Avatar
zz2h33
even my 16 says DOT 4 on the caps, and they make a synthetic DOT 3/4 as well.
Old 07-21-2016 | 08:21 AM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
That's because of your ABS. Harley switched from DOT 5 silicone to DOT 4 glycol in 07? when they brought out ABS.
The OP's 04 RK should have come stock with DOT 5 silicone brake fluid, afaik.
Old 07-21-2016 | 08:34 AM
Campy Roadie
All Dot 3/4 brake fluids are synthetic. The important difference we're talking about here is glycol based and silicone based. A completely different thing.
Old 07-21-2016 | 08:58 AM
Cpl Ed's Avatar
Cpl Ed
My bike is an '04 Road King. I just looked at an old receipt from the last brake job performed at the dealer, (10 yrs. ago). Part # 99953-A Dot 4 brake fluid. That's all I've ever used.
Old 07-21-2016 | 10:02 AM
foxtrapper's Avatar
foxtrapper
It'll work. That said, take a look at your service manual or your owners manual. You'll see DOT 5 is what is specified. Part number 99902-77.
Old 07-21-2016 | 10:23 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by RKZen
What's the color of the fluid in your bike? If it's purplish, then it's DOT5.
The "purplish" color doesn't last for long...not a good way to determine what is in your bike.
Quick Reply: Brake Fluid........sorry to ask
