Rattling Chain Noise on Deceleration
Old 07-20-2016 | 09:27 AM
Geoff's Avatar
Geoff
Default Rattling Chain Noise on Deceleration
I have an 06 Ultra Classic with 45k miles. It recently started making a rattling chain noise. It's most noticeable on deceleration, but I also hear it when riding at a constant speed in 4th gear. It happens when the engine is cold or warm. I only hear the noise when the bike is moving. I checked the following but didn't find anything:
- Heat shields
- Front motor mount
- Saddlebag support bracket
- Rear muffler mount rubber blocks
- Exhaust header flange nuts
- Floor board mounts
- Kickstand hitting metal
I did not check the primary chain adjuster.
Any ideas would be appreciated.
Old 07-20-2016 | 09:35 AM
skydude426's Avatar
skydude426
I'd check the primary chain adjuster.
Geoff (07-20-2016)
Old 07-20-2016 | 09:47 AM
Geoff's Avatar
Geoff
Should I check primary chain free play with a cold or hot engine? My manual says it can be done either way.
Old 07-20-2016 | 01:35 PM
skydude426's Avatar
skydude426
You can do it either way, but I prefer to let it cool down. It's easier to work on.
Old 07-21-2016 | 08:43 PM
TUCCI's Avatar
TUCCI
- Heat shields
- Front motor mount
That's the only thing left that's prob the cause, the chair deflection and the functionality of the adjuster.
Geoff (07-22-2016)
Old 07-22-2016 | 02:22 PM
Geoff's Avatar
Geoff
Problem solved!
The primary chain adjustment was spot on. The problem was the (2) Torx bolts that secure tour-pak support bracket to the frame. One was very loose, the other came loose and fell off the bike.
After spotting this I think I checked about every fastener on the bike. I used a torque wrench on critical fasteners.
Old 07-22-2016 | 02:32 PM
skydude426's Avatar
skydude426
Glad you solved the problem. I bet you learned a few things about your bike in the process b
07streetbob07
05-16-2018 07:33 AM
1harleyman
04-02-2017 08:30 PM
46u
63
09-08-2015 05:10 PM
BlackFLHR
05-03-2010 01:29 PM
mike_oh
04-08-2008 03:46 PM
Quick Reply: Rattling Chain Noise on Deceleration
