Clutch Friction Zone adjustment
Old 07-18-2016 | 02:51 PM
dajogejr's Avatar
dajogejr
Default Clutch Friction Zone adjustment
Adjusted my clutch at the beginning of the season (Turn in until contact, back out half turn, tighten down) and set the free play in the cable accordingly.
I want to move the friction zone closer to the handlebars a little bit.
I understand it must disengage and engage completely.
My question is, when I go to adjust it, cold, is it less than a 1/2 turn out from contact or more?
TIA
Old 07-18-2016 | 02:54 PM
danzio's Avatar
danzio
My manual says the clutch should ALWAYS be adjusted at room temperature.
Old 07-18-2016 | 02:58 PM
dajogejr's Avatar
dajogejr
Yep... When I said cold, I meant unridden...
Old 07-18-2016 | 03:10 PM
qtrracer's Avatar
qtrracer
3/4 of a turn would bring it out further. At least thats how I see it.
dajogejr (07-18-2016)
Old 07-18-2016 | 03:16 PM
dajogejr's Avatar
dajogejr
That's what I was thinking as well, So I need to go less than 1/2 turn to get it to engage closer to the bar (pulled all the way in).
That's what I'm looking for.. Quicker engagement from pulled in.
Old 07-18-2016 | 03:32 PM
qtrracer's Avatar
qtrracer
Maybe I am not saying what I mean very well. 3/4 of a turn should have the engagement zone further IN to the grip. Closer in would have been a better way for me to say it.
Old 07-18-2016 | 03:40 PM
dajogejr's Avatar
dajogejr
Hmm... Ok, I'll try that first.
Thanks!
Old 07-18-2016 | 03:43 PM
skydude426's Avatar
skydude426
I think the Allen screw on the clutch park adjusts the width of the friction zone.
The cable adjustment sets how close to the grip it is. If you loosen it a little ( add a little slop to the able). It should move the friction zone closer to the grip.
Old 07-18-2016 | 03:48 PM
qtrracer's Avatar
qtrracer
Far as i know each adjustment does the same thing. I set the 3/4 at the clutch first then set the free play at the lever to suit me. I cannot see how the adjustment at the basket could change the width of the friction zone. Heck there is a ton of stuff for me to learn, so maybe someone could explain how it would.
Old 07-18-2016 | 03:50 PM
Rickr01's Avatar
Rickr01
3/4 would bring the lever closer to the bar. I set mine to 3/4 as I like my clutch (Friction Zone) engaging closer to the bar. People get confused as its opposite from what you might think.
Quick Reply: Clutch Friction Zone adjustment
