Clutch Friction Zone adjustment
Old 07-18-2016 | 08:38 PM
dajogejr's Avatar
dajogejr
Well, gave it another stab. I think I may be turning in too much then counting out 1/2 to 3/4 turn.
When it just starts to touch is kinda hard for a big ham fisted lug like me.
Is there an easier way to get the feel for this?
Turned it out 3/4 and it didn't change the engagement point much.
Going for a nice 200 mile road trip tomorrow, maybe I'll feel different tomorrow after the ride.
Old 07-18-2016 | 11:47 PM
Buelligan666's Avatar
Buelligan666
Turn the set screw with your finger tips. Use light pressure and when it stops you should be lightly touching.
Highwayman-AL (07-25-2016)
Old 07-19-2016 | 12:08 AM
TriGeezer's Avatar
TriGeezer
The procedure " Clutch Adjustment The Easy Way" sticky in the clutch sub-forum worked better for me.
Old 07-19-2016 | 05:34 AM
dajogejr's Avatar
dajogejr
Thanks again, read up on the easy way sticky, and I'll try the finger tip method as well.
Appreciate the tips fellas.
Old 07-19-2016 | 08:27 AM
bill from tn's Avatar
bill from tn
I adjusted mine last night and I have a pretty good feel with my fingers but also never am really sure when the adjuster screw touches.
I noticed this when adjusting. When I turned the screw in, I could see primary oil just start to close up the gap on the outside of the discs. That's when I knew I was moving something. As mentioned, use your fingertips to thread it in.
3/4 turns back works best for me. If you want your lever closer to the bar, put some extra play in the cable adjuster. I like mine a little loose. My lever loosens up as the drivetrain warms up.
dajogejr (07-19-2016)
Old 07-25-2016 | 10:42 AM
dajogejr's Avatar
dajogejr
Took care of this Saturday. I used just my fingers and not a T Handle. I went back and forth tightening/loosening several times to get what I felt was initial contact.
Went out 3/4 turn, marked it with a Sharpie to make sure when I tightened it down, it didn't move.
Just where I want it now... thanks for the advice all.
Old 07-25-2016 | 01:55 PM
t. sawyer's Avatar
t. sawyer
i adjusted mine with the lever to close to the bars. worked fine till engine warmed up, then it was partially engaged with lever flat against bars. that was 3/4 turn. But all that is feel and I feel things differant than you. I like it farther away from bar to engage. much easier on the hand at stop light. quicker to shift thru the gears. the friction zone seems to be easier to operate. jmo
kroozeabout.
Old 07-25-2016 | 02:02 PM
dajogejr's Avatar
dajogejr
kroozeabout.
On "My" 3/4 turn... my friction zone starts just about an inch off the bar from the bend in the lever.
It was out a hair more before.
I agree, I'm of the school of pulling in the clutch at lights, stops, etc., and keeping it in gear. I also stop with left leg down only, right foot on the brake.
It's right where I like it now. I'm 100% certain I get full engagement and disengagement.
Old 07-25-2016 | 06:29 PM
ORradtech's Avatar
ORradtech
Yep, the trick is to use your fingertips and runit in and out several times. You will start feeling the exact point it touches the spring. Then it's just a matter of backing off the amount you like.
I'm running the Energy One kevlar +1 clutch with the heavy duty spring and 3/4 turn is pretty spot on for me.
handirifle
06-26-2019 11:35 AM
Lang47
08-26-2013 12:08 PM
pt4u2nv
07-31-2013 03:50 PM
Grizcat68
05-16-2011 09:17 PM
tincup64
EVO
03-06-2011 08:34 AM
Quick Reply: Clutch Friction Zone adjustment
