tranny clunk
After smoking a primary bearing I went to a manual primary chain adjuster. Very noticeable, improved, difference in shifting. Also used 10w30 oil (and put the gas cap on the seat when refueling) bwahaha. I won`t tolerate the OEM chain adjuster again. The over tightening of the primary chain (with OEM adj.) takes its toll. As an example I once experienced the damage done from a belt drive. A buddy butchered a belt drive on his super glide and it trashed the engine sprocket bearings in 100 miles. It was a fresh rebuilt engine that succumbed to the over tight drive belt. Expensive.
nothing to do with the tranny and everything to do with the clutch mechanism. Hold your clutch in at a stop light and and rev up engine before you shift into first. no clunk. or when the bike is cold when first started, pull in clutch, roll the bike backwards, which is breaking the clutch plates free and then shift into first. No clunk. its all about the clutch.
75w -140
real tranny gear oil 75-140 worked wonders for me Ive done it to both softails
run super light weight redline w shock proof or amsoil 20-50 in primary
you will be amazed ..... I hate the clunk as well and have tried multiple variations to make it better .... my 09 softail is better that the 05 fatboy ... but straight cut gears I cant over come completely ..... but its like night and day .... difference
one has royal purple syn 75-140
one has lucas 75-140 syn redline in both primarys
Beary
clunk
Funny, I have an '08 FLHT that I bought new. Now over 108,000 miles on the clock. It clunks putting it in gear from neutral, but doesn't clunk after that. I did change the clutch to a Barnett extra plate, with stock pressure plate, but even all stock, it worked fine, with no extra noise when shifting. Perhaps your technique for shifting different than mine, I don't know.
