LED Tail Light with Strobing Brake Light
I just installed an LED tail light with strobing brake light on my 15 RGS from Fast Lights, it's actually a Radiantz tail light I think.
It looks awesome and works great but I'm getting the red security light on my speedo gauge when I hit the brakes, stays on while the strobe functions then goes out when the brake light goes solid.
A couple of times it stayed on for a few minutes then went out.
I know it has to do with the can bus system but will it ever go away?
Anyone had this? Is there a fix?
Clear any codes and try a setting with normal break flash instead of strobe. If that works fine you may be stuck with it. Bus is likely seeing no brake light at some point during strobe mode.
On another note, have heard some states frown on strobe type lighting on anything other than emergency vehicles.
Would the "run the emergency 4 way flashers for a while" trick work here to retrain the computer, or is that only for LED turn signals?
Ndotson19
09-08-2018 10:19 PM
