Checking Road King tire pressure (easy way)
I center the valve stem at the bottom and use this right angle gauge....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You taking the saddle bag off??????????
Cheap parlor trick to waste time and money. Had a value when oil chains. but that is before your time.
Some of you people should park or sell your bike.
Unless you are looking at going to the nursing home. Fat?
It embarasses me at times to say I ride a Harley.
I'm embarrassed you ride a Harley, too.
If you've got the SPOKED WHEELS you'd have a better grasp on just how difficult it can be to get to the valve stem. NO you cannot use the 90° valve stem if you have tubes which many of the scooters in question do have. As mentioned earlier the HD 42300009 will make this much easier to accomplish and is easy to store on the scooter in the event that you're out on the road and need to add air for whatever reason.
Embarrassed? Because someone you don't even know doesn't live up to the expectations that you ( like you're the determining of what a big bad *** biker is ) ascribe too? Give me a break! BTW ... Nothing personal? :>)
crazytown (07-13-2016)
feed this down thru the spokes and fill/check in one step:
https://www.amazon.com/gp/product/B0002SRL20
The reason you get embarrassed by the thoughts, actions, and words of other people is because your self worth is minimal at best.
In an attempt to shore up your sagging self image you made a purchase of a motorcycle and a specific brand in hopes that in the school lunchroom you will be asked to sit at the "cool kids" table.
Real life then shows up and you are back to square one. Your plan didn't work out. What now?
I've been using this for several years and works great. Easiest with the bag off but once you try it a couple of times it gets easier to use with a little practice. Makes it much easier if you have to add air too.
The OP was simply asking if someone more experienced knew of a better way. I don't get why some guys have to be such douchebags.
