Docking confusion
Old 07-09-2016 | 08:37 AM
SiggerTX's Avatar
SiggerTX
Default Docking confusion
I have an 06 FLHT. If I install the proper 4 point docking hardware can I use any of the backrests or tour Pak mounts? Most that I see are 09 and up.
Old 07-09-2016 | 08:51 AM
Smokey Stover's Avatar
Smokey Stover
Probably not, They're actually a 6 point system, With the foreward most points using the shock mounts inside the shocks.
Old 07-09-2016 | 09:26 AM
decencyxdefied's Avatar
decencyxdefied
The docking setup is different from 08 down and 09 up.
Old 07-09-2016 | 10:20 AM
head's Avatar
head
On a '06 model, three sets of mounts would cover most applications. If you install the forward two mounts, a detachable backrest would go there. The tourpak mount uses one of those and one more is needed.
Head
Old 07-09-2016 | 10:47 AM
sr230mike's Avatar
sr230mike
What they said. You need year and model or year and model group ie 07 to 99. Go to the Harley site and check fitment. Mike
Old 07-09-2016 | 09:50 PM
SiggerTX's Avatar
SiggerTX
Ok so I see plenty of the four point docks, but does the qd tour Pak mounts require a 6 point? Is that something you add to the 4 point docking setup or do you have to buy a specific 6 point docking kit?
Old 07-10-2016 | 02:07 PM
JimTJr's Avatar
JimTJr
I believe it's the same design for both generations. 08 and back, and 09 and up. The Luggage rack, and Tour pack use the four actual docking points on the 4pt docking station. The Passenger Back rest, uses the top of your shocks, and the front two docking points. Then if you had a luggage rack on it with the Passenger Back rest,, it used all 6 pts at the same time.
tlar1540
08-06-2013 09:59 PM
03 Fatboy
03-16-2010 06:42 PM
DPete
05-14-2009 11:31 AM
exitclub
04-22-2009 09:55 AM
Cheeze
03-25-2009 05:59 PM
Quick Reply: Docking confusion
