New 2015 Road Glide Special, corrupt GPS
OK fine. You know how it works. You know it wasn't a user error because you know how the GPS works and you read the manual.
You should know that it's not a software issue since you are running the same version as your buddies.
Guess you should probably find a new dealer to fix it for you? One that knows the unit is NOT a Garmin! And knows how to verify satellite signals are strong enough to give a correct set of location coordinates.
BTW -
If the unit picks up at least 3 satellites, it will find its' location correctly. If it does that, then the issue is OPERATOR ERROR. But since we've been able to rule that out already, guess the dealer will need to replace the radio?
Good Luck. You're gonna need it.
The HD Infotainment system only has 2 BT profiles: the HSP profile which allows 2-way for telephone calls and the A2DP profile which allows music streaming in stereo. In both cases the HD unit acts as the slave device. If the Garmin device uses the A2DP profile & is master, it may be possible, but I am unaware of anyone that has made that work.
Use the instructions in post 10 to check your gps signal. You should be able to see how many satellites you are picking up and how strong the signals are. If possible, compare it to another bike in the same location. If you have a significant difference in your signal or number of satellites then I'd be looking at the gps antenna and wiring. I'm not sure if there are any diagnostic steps to let you determine if it's the antenna or the Boom itself without swapping a known good antenna once the wiring has been verified as ok.
Brit Biker
Road Trips
08-06-2015 03:08 PM
Olde Skool
04-04-2012 09:27 PM
