Pre-Rushmore LED conversion.
Old 07-07-2016 | 06:32 PM
bikerlaw's Avatar
bikerlaw
This is all excellent info, but what can I do to his bike to get both bulbs on? It has to be possible.
MK, haven't found your thread yet, but will look tonight.
Old 07-07-2016 | 06:47 PM
Punjabi Rider's Avatar
Punjabi Rider
Harley makes a harness to make this job easier I had that installed on my 07 not sure if still available you might want to check with a dealer. There is a thread here shows the wiring need to unplug and plug into different pin under the fairing cap HD plug n play also goes under the fairing cap it's just little too big for that small area.
Old 07-07-2016 | 08:28 PM
Dguy's Avatar
Dguy
This is the answer. I bought the dual bulb setup that is on the 14's and newer for my 12 SG and it came with the harness. Low beam is one bulb and high is both. I removed the bulbs and went with Fuel Moto leds and it works the same!
The harness part # is 73272-11
Old 07-07-2016 | 09:53 PM
bikerlaw's Avatar
bikerlaw
Woo-Hoo!!! This is what I was hoping to hear.
Thank you all for the great input.
Old 07-08-2016 | 07:31 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by SnoRider
It seems as though pre '14 dual bulb lamp - low beam is off when high beam is on, Rushmore dual bulb allows for both the bulbs to light when high beam is on....
That applies to all vehicles with twin filament bulbs, only one filament burns at a time. The exception AFAIK are twin-element brake light bulbs.
Old 07-08-2016 | 08:33 PM
ORradtech's Avatar
ORradtech
Harvey's dual halogen conversion comes with the harness and it is/was available separately. But there is a wiring mod you can make that consists of moving one wire. The model is in a fairly recent thread. It's free and should take up next to nothing extra room.
Old 07-08-2016 | 08:49 PM
SnoRider's Avatar
SnoRider
Can you hook us up with a link...or a search word?
UltraZac
07-30-2017 03:12 PM
clap
02-24-2016 01:21 PM
asianiron
01-31-2016 12:51 PM
bikerlaw
12-26-2015 04:13 PM
Sandy H.
03-16-2015 10:50 PM
Quick Reply: Pre-Rushmore LED conversion.
