StreetGlide cams
Let me give you what i found out....i have the S&S 585 gear driven in mine....i wanted to be able to go fast on highways.....my mistake...i never run the rpm's above 4-5k ...so these cams don't come alive.....because of all the crap i did to my bike, i am not about to change to another cam manufacturer and my compression rules alot of other cams out. So i will simply put either the 583 or the 551.......hopefully it will not be painful.
I also upgraded to the '95 ....
Make sure you do your homework before deciding.... Talk to the experts at your local HD that actually does the upgrades...not your normal tech.
Good luck....
Good luck....
Good luck....
Good luck....
