Highway Pegs Flopping around
Guys,
Anyone take the time to install a ball plunger in their highway pegs? I recently purchased some Kuryakyn Switchblades and their Brute mounts:
Issue is, I'd like for them to stay folded up. The male section of the Switchblade has a profile which looks like it was made to for a ball plunger...But I'd need to install and drill through some fairly stout metal in the mount, then run a tap through. Anyone do this; or am I overthinking it?
Thanks!
Steve
Thanks!
Steve
Knuckelhead (07-03-2016)
They are most likely flattened out and are now useless, try replacing them. I think HD gets $7 for 2 of them. Did you have them installed in the right position? The flat square goes in against the bracket mount, and the rounded bow is what the peg goes against. Not sure if this is explained right. But if the other way the clip will just lay over the smaller ped end and there will be no tension against the peg.
I had the kurykns that flip down. They eventually just broke and fell off, the whole thing.
Know I just have the mount for them. Enough to put my toes on and protect lowers.
Personally I feel highway pegs are bad for back. I used to get sore hips.
I don't use my backrest anymore either. Didn't seem to get me in right position, and created pain. Rode to Alaska without it.
I think my local ACE hardware is open until noon tomorrow, so I'll find some of these that should do the trick:
Did you try putting a D on either side of the pegs and see if they hold up?
