Enforcer 19" Front Wheel Swap Questions
Hi I am new to the forum and just recently upgraded to a 2008 Road Glide without ABS, I just purchased a 19" Enforcer Front Wheel Take Off from a newer bike. While doing some research I found that the abs bearing has to be swapped out to HD part # 9276 A which is a non abs bearing, for the 25mm axle. I was wondering do I need to order two of these bearings or is there another HD bearing that goes in the wheel that is different? Any help would be appreciated.
Thanks
Thanks
Just gotta swap in the non abs bearings that would have came in the wheel if the Rushmore bike that it's off of wouldn't have had abs. I put a 19" enforcer on my 2008 roadking. It came off of a 2014 streetglide standard that didn't have abs. It bolted right up to today the 2008 perfectly using the original spacers from my bike.
Thanks for the reply..
IWas finally able to find the info here on the forum..
The wheel doesn't appear to have ABS bearings as they are black and not grey but I will check part # to be sure.
I may just powder coat it while it's waiting..
Appears to be a pain in the *** to polish and then clean up the black contrast.
