First out of warranty fault
Old 06-30-2016 | 06:52 AM
skid_pimp's Avatar
skid_pimp
Originally Posted by us1fountain
I'm not convinced so much that the bolt is the problem, regardless of which torque spec is used, or the quality if the levers and/or shafts. When I look at the levers, there is a lot of meat there that needs to be pinched tight around the shaft. And given the dia if the bolt, it'll be hard to pinch the levers tight without taking the bolt to its limits. Seems a better fix is the levers need to be made with either a little less meat to them, or a relief slot added to the opposite side of the shaft from the bolt hole, allowing the bolt to pinch the levers tighter by having less material to overcome in order to pinch.
Exactly what limits are you concerned with on that bolt? It's limits far exceeded the requirements for its use...
Old 06-30-2016 | 09:03 AM
CVO SG's Avatar
CVO SG
Poor description of the bolt on my part. what I see is the levers are of issue. Just to much steel in them to deflect in order to pinch down
Old 06-30-2016 | 09:04 PM
skid_pimp's Avatar
skid_pimp
It pinches down perfectly as designed, as long as it is kept tight. And if too much metal was removed you would loose structural rigidity, and or the spring effect would be lost, and the metal would not open up when the bolt was removed, making removal more challenging.
Sandcrab
2014-2023 Touring Models
21
08-29-2018 04:49 PM
Greg Di
01-20-2017 12:22 PM
1st 96 ultra
06-30-2014 10:23 AM
Twinrider
08-21-2011 01:26 AM
shawn e.
03-14-2009 01:42 PM
Quick Reply: First out of warranty fault
