Performance question.
Old 05-20-2007 | 07:05 PM
Brooklyn Redneck's Avatar
Brooklyn Redneck
Default Performance question.
I recently upgraded to andrews 26g cams, 95" pistons,and screaming eagle heads,also running with a pcIII,and vh tru duals. The problem comes when going through the gears, pulls real hard through the first half of each gear then seems to really flatten out,almost like I missed a shift. Is this a map problem,like not enough fuel in the upper rpm range,ormaybe to small a cam for this setup?? I'm confused any help will be greatly appreciated.Thanks
BR
Old 05-20-2007 | 07:15 PM
PhilM's Avatar
PhilM
Default RE: Performance question.
THe Andrews 26 is a bolt-in cam that is "designed" to perform best with stock compression and the flow rate(s) of stock heads.
You are likely close to 10:1, if you have S/E perf heads vs. 9:1'ish that stock is. Furthermore, the 26 is a low end torque cam. It will fall off over about 4000~4500 RPM. It is also quite likely that you'll experience some pinging at that CR with 26's.
In that build, you probably be better off with S&S 570 cams~ like the "Hippo Build".
Old 05-20-2007 | 08:14 PM
nvsteve's Avatar
nvsteve
Are you bumping therev limiter?
What rpm does it feel like it flattens out.
Old 05-20-2007 | 09:22 PM
Brooklyn Redneck
I don't think I'm at the rev limiter, it's starts to flaten out at about 4500 rpm.
Esco11
Engine Mechanical Topics
02-28-2018 03:15 AM
Eastcoast Jim
09-13-2016 08:41 AM
Puglia10
03-10-2014 07:26 PM
Psycho
02-25-2007 09:35 PM
BaggerDave
Exhaust System Topics
01-08-2006 07:21 PM
Quick Reply: Performance question.
