Amp Switched Power
Amp Switched Power
I'm wanting to change where my amp gets its turn on power from. Currently I'm using the White/Orange wire in the headlight wiring harness. I don't like the feed back I get from the headlight in the radio. I'm thinking if I change its location I can get rid of the feed back.
Any ideas where to get an ignition power from besides the White/Orange wire?
Red is hot, black is ground. Your interference problem is probably a ground issue, not the turn on power. Is your amp grounded at the battery? If not, it should be.
My amp is grounded at the battery. It gets its power and ground from there.
JW Speaker Evo 2. I had LED bulbs prior to the JW light and it was worse, even with RF filters installed. It got better when I changed to the JW headlight and removed the RF filters, but not completely gone. I don't get near the reception that I got with the standard bulb.
