Modding Drivers Backrest To Lower IT?
Old 06-21-2016 | 04:48 PM
Bodacious MC's Avatar
Bodacious MC
Default Modding Drivers Backrest To Lower IT?
Has anyone tried with success to rework the mechanism that slides into a HD adjustable backrest to make it even lower than the lowest hole position drops it to?
I bought a used backrest and need to pull the pad off and make some repairs within it. I'd like to drop it so that it's another 1-1.5" lower than it normally can go, so that it sits closer to the seat top.
I know...another stupid idea, but I'm full of them.
Old 06-21-2016 | 04:52 PM
mkguitar's Avatar
mkguitar
cut the 2 rods and remove some of the length and then weld them up again.
mike
Old 06-21-2016 | 05:01 PM
OldMike's Avatar
OldMike
It's not stupid, it's a great idea to move the backrest down to cradle the curve of your back and make a very comfy ride.
Cut a section out of the post and get welded or inside the backrest itself I burned a hole in the plastic with soldering iron and shoved the post up as high as it would go, jammed some scrap behind the bolt to hold it. Still using it 3 years later.
Old 06-21-2016 | 05:36 PM
Litewings's Avatar
Litewings
Did it to mine. Cut the 2 rods and removed 2", than welded it back together. Then added more padding to the bottom of the backrest.
Old 06-21-2016 | 05:43 PM
dansflhti's Avatar
dansflhti
I just bought one of these back rests a few weeks ago and was wondering the same thing.I'm kinda short and during my trip to Americade I was wishing it was a bit lower.
Old 06-21-2016 | 05:57 PM
deni's Avatar
deni
I cut & welded two inches lower. Flat bar style (not round rods). First cut at the factory weld, so my weld blended & is hidden. I still have two inches of vertical adjustment. Man I can't believe how horrible it looked before even on the lowest setting. Who designs these things ?
Anyway, when you prep the metal to rejoin, lightly bevel both pieces 360 deg. where they butt together for good weld penetration.
Old 06-21-2016 | 06:01 PM
Bodacious MC
Thanks mine has the Rods, flat bar type would be much easier. Tomorrows project!
Old 06-21-2016 | 06:03 PM
Bodacious MC
2" lower will be nice
Old 06-22-2016 | 09:33 AM
Bodacious MC
Now that's a 100% better looking lowered to the top of the seat!
Old 06-22-2016 | 09:54 AM
dansflhti's Avatar
dansflhti
How did you get that do soo quickly?
Quick Reply: Modding Drivers Backrest To Lower IT?
