3M Paint Defender Spray Film on fairing
Well, prepped and resprayed. It has that 'milky' color till it dries.
I sprayed outside in the yard once but too many things fly into the wet spray (knats, leaves, fuzz from cottonwoods etc) so now spray in the cellar. Once it solidifies a bit will put in the yard for a few hours of sun. Then let it sit a few days to cure.
sprayed.
supposed to remove the tape while its wet else the goo may dry on the tape and when you pull it off, it pulls off the dried coating.
instructions call for 2 layers of tape, but thats on a car hood. I think I used 2 before, but not this time.
no issue if it 'runs'. It dries clear so even a chunky drip isn't quite noticeable, esp in an area around/under the headlight no one sees.
sprayed.
Big L (06-15-2017)
