SOS!!! Dad stranded on side of the road 1000 miles from home!!!
Old 06-16-2016, 03:18 PM
Rhino-1's Avatar
Rhino-1
Rhino-1 is offline
Originally Posted by Zerk
No ****. Your charging system failed.
'xactly... It's a little different than "just" draining your battery from leaving the lights on a little too long.
On a side note, a battery that has been damaged thusly can usually be reconditioned with a "conditioning charger thingamajig," or a "smart" charger that has this feature.
  #32
Old 06-16-2016, 03:20 PM
RK_Classic's Avatar
RK_Classic
RK_Classic is offline
Received 6,095 Likes on 2,693 Posts
No **** found that out!!!
  #33
Old 06-16-2016, 04:43 PM
Zerk's Avatar
Zerk
Zerk is offline
As soon as bike starts, charging system is making power. Higher RPMs more power. At idle you may not have enough. Raising rpms will help.
Battery is for staryin bike. It may supplement charging system at idle.
  #34
Old 06-17-2016, 07:34 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,600 Likes on 978 Posts
Those of us who are old enough, remember the trick of pulling the battery cable off a running car to check the alternator output can keep it running. That's not a good idea for new cars/bikes that depend on computers/electronics to run. The alternator/regulator put out DC current but not steady - it's lots of little pulses as each magnet goes by a coil. The battery steadies these pulsations and protects the electronics. When the charging system is running full force to charge a dead battery, those pulses get out into the bike's electrical system and could cause problems.
jorgester02@yahoo.com
04-03-2024 06:16 PM
ctfrmvallejo114
12-02-2017 06:18 PM
SpaceCoastHarley
12-29-2014 08:37 AM
vrrnitro
06-11-2013 01:27 PM
mchris
02-12-2012 06:28 PM
Quick Reply: SOS!!! Dad stranded on side of the road 1000 miles from home!!!
