What causes a stator to go bad?
I replaced the original one about two years ago and the "new" one is needing to be replaced. I have 65k miles on the bike, it is an 09. I did upgrade to a 107 before the first replacement if that matters.
Thanks
Thanks
all of the above. heat ,crappy wiring (shorts), cheap parts, bad battery or voltage regulator. loose wiring (bad grounds). i've seen people with wires just twisted together over the years and they wonder why their **** goes out. that being said, old age and alot of use takes it's toll over time. it sure seems the newer stuff doesn't hold up as well as the older stuff.
www.cycleelectricinc.com
Get the whole kit(stator/rotor/regulator) and change your primary fluid every 5000 miles or twice a year.
At the risk of not being politically correct in the eyes of all the "Kool Aid" drinkers here, I am thinking that the No. 1 reason that so many stators fail on newer bikes is that the MOCO buys the cheapest components that they can source in the hope that they will last 24 months before they croak. My bet would be that they have a supplier in China for stators but I don't know that for a fact, just a guess on my part.
