Flash or No Flash after speaker upgrade
Friends,
I have a 2015 SG Special. I am looking to upgrade the front speakers to Hogtunes or Biketronics..just the speakers and no external amp...want to use the factory amp with them.
Do I need to flash or they will perform good without the flash? I understand harley has their speakers mapped to the processor inside.
Friends, I have a 2015 SG Special. I am looking to upgrade the front speakers to Hogtunes or Biketronics..just the speakers and no external amp...want to use the factory amp with them. Do I need to flash or they will perform good without the flash? I understand harley has their speakers mapped to the processor inside.
If you're referring to no amp, don't bother upgrading just the speakers. Of course anything is better than stock, but good aftermarket speakers need power that the stock head unit doesn't have to drive them.
Go to the audio section. A bunch of great guys over there that will help you out. To answer your original question, stay away from the flash , the audio guys will explain.....
Remember good speakers need power, if you do not supply enough power to a good set of speakers then you are wasting your money, they will sound worse than a set of crappy spearkers with to much power.
Do your home work before changing/adding stuff....
As others have said, go to the audio section poke around and ask questions.
Friends,
The stock speakers are 2 ohm. Any speaker that you use to replace should be 2 ohm or you will cut your power in half and thus lowering the total SPL you get out of them. (example: 25 watts @8 ohm/ 50 @ 4 ohm/ 100 @ 2 ohm.)
If you are only replacing the speakers then you do not need to do a flash. The reason you have to flash the bike when you add an amp (some brands) is to tell the head unit to reduce the voltage output to match the input of the amp. In the case of a stage 2 it also tells the head unit the cutoff frequencies for each channel.
Amp like the Rockford amp have adjustment pots on them so there is no need to flash. The Harman amp (known as HD boom) doest not have adjustments; therefore, flash is needed.
I just did my own stage 2 amp/speaker install and took it to the dealership to get flashed. The tech only did a firmware update because HE (not me) was mixed up. So make sure they hook your bike up to the computer and do a real flash. They covered the cost of repair.
Joker
