How do you get the primary cover off-floorbard
Good thing I checked before I drained it. I have an 05 Electra glide Classic EFI and last night I changed most fluids except the primary. How do you get the passsenger side floorboard off to access the one primarycover bolt behind it?? Is it just that 1 allen bolt that holds the floorboard on or more? Is there a trick or a tool?? I wanted to get this done this morning before my wife and kids are up and just eat up my day.
RE: How do you get the primary cover off-floorbard
You should not have to remove a floorboard to drain or refill the primary. If you do want to remove it however, there is just on socket head cap screw holding it (passenger floorboard) on. Fold the board down, remove the bolt and pull it out.
Chuck
Chuck
use the drain plug under the primary to drain and then refill through the access cover in the center of the primary cover or through the clutch access cover (derby cover). You can't refill it by removing the primary cover. What's going to hold theoil if you have the primary cover off?
