03 UC popping accessory fuse
Old 05-23-2016 | 06:13 PM
elite51203's Avatar
elite51203
Default 03 UC popping accessory fuse
Ive had my bike for almost a year now, and the accessory fuse has popped twice for an unknown reason. What does this fuse control and why would it be popping?
I use my iphone with the cable that plugs into the radio jack for music. Thought that could be it?
Old 05-23-2016 | 06:49 PM
dawg's Avatar
dawg
Do you plug it into the cig lighter to charge?
Old 05-23-2016 | 07:25 PM
elite51203's Avatar
elite51203
Negative. I noticed that it may have popped when I hit the horn button.
Old 05-23-2016 | 07:31 PM
ORradtech's Avatar
ORradtech
Have you got a factory service manual? You can fi d out what all that fuse feeds.
It's not likely to be anything you plugged into the radio. Id think the radio would have its own fuse.
Old 05-23-2016 | 10:51 PM
im's Avatar
im
Do you have some kind of special after market horn ?
Old 05-25-2016 | 04:43 PM
elite51203's Avatar
elite51203
no aftermarket horn. maybe its a short somewhere.
Old 05-25-2016 | 07:13 PM
dawg's Avatar
dawg
If it pops when you hit the horn, yes probably a short. Check the wiring under the switch caps and see if one is pinched/rubbing through. If not there, check where the wiring goes over the fairing brackets, been known to rub through there as well.
Old 05-25-2016 | 08:46 PM
Vernal's Avatar
Vernal
The accessory fuse is a pretty busy circuit:
Old 05-25-2016 | 08:50 PM
nvsteve's Avatar
nvsteve
In 03 there was a recall/service bulletin to upgrade the circuit breaker to 50 amp on touring bikes with fairings. Could be your problem.
Asuperglide
Electrical/Lighting/Alarm
03-30-2015 12:30 PM
Webo
01-27-2014 05:41 PM
GzrGlide
05-22-2010 11:37 PM
SFarace20
07-23-2007 12:47 PM
abreitbach
05-30-2007 06:38 PM
Quick Reply: 03 UC popping accessory fuse
