no brake lights!?
no brake lights!?
I have an 04 Road King Custom. I now have Bad Dad LED tail lights which function as run/stop/turn. I have added a Bad Lands load equalizer and Harleys plug and play adapter to allow the 3 functions. I currently have absolutely no brake lights. The relay clicks only when I grab the front brake but still no lights. I have checked all the fuses, they are all good. I unplugged the rear brake switch and jumped it with no change. The running light and turn signal functions work just fine. I am running out of things to check other than each individual wire to see if there are any cuts of nicks in them. does anyone else have any ideas?
+1. From experience. On my bike the wiring schematic does not show the 3 black wires splitting to feed the turn signals and running lights. I found out the hard way that one of the black wires is not ground, but hot. Blew the accessories fuse. Replaced it with another 15A fuse and all is well.
Oh, another thought. Some LED's are polarized. If you have a two wire for the brake light, switch the two leads on the lights and see if that helps.
Check your Cruise/Brake fuse again. If it's good pull the brake relay, turn ignition on and check Socket 4E for 12V that's the O/V wire from the Cruise/Brake fuse.
Either brake switch should give you 12V to socket 3E on the relay base, R/BE wire.
If everything looks good unhook connector 7b on top of fender under the seat and check the R/Y for 12V with brakes on, is that where the Bad Dad is connected?
The rear brake switch should have 12V on the O/W wire from the accessory fuse.
Good Luck
Bill
Good Luck
Bill
This is the 1st thing to check. And btw all LEDs are current-directional, so if you plug in the bulb or hook it up backwards it isn't going to work.
